Upgrade Guide > Preparing Siebel Application Data for Upgrade > Setting Up Campaign Status Values for Siebel MarketingUpgrades from: Siebel 6.x, 7.0.x, & 7.5.x. Environments: Production test, production. This topic is part of an upgrade process. See How to Perform a Siebel Database Upgrade. This optional step is not required for upgrade processing, but will simplify program and campaign reporting by making historical values equivalent with the values used as of Siebel 7.7. The database upgrade process expects the standard Status values for the following applets. The process uses the standard values to convert records to the new campaign model during the upgrade:
If you customized the values for the Status field for these objects, convert the Status (S_SRC.STATUS_CD) of any existing records to the standard values before doing the upgrade. Any campaign records that do not have standard Status values will not create Load Wave records during the upgrade and will not be displayed as launched campaigns in the Campaign Agent views. Optionally, you can also migrate the status values for the following components: Table 29 lists the standard Status values for each object.
Table 30 lists search specifications for locating records containing Status values. Siebel 7.5 terminology is used for the object names.
Upgrade Guide | Copyright © 2006, Oracle. All rights reserved. | |
