Table 22. Information Required for the Database Server Configuration Utility
Siebel Gateway Name Server Address |
Windows only. The Siebel Gateway Name Server machine name and the Enterprise Server name. |
Siebel Server Directory |
The absolute path of the directory where the Siebel Server is installed, for example, D: \sea78 \siebsrvr . For UNIX, do not enter the string $SIEBEL_ROOT. |
Siebel Database Server Directory |
The absolute path of the directory where the Siebel Database Server is installed—for example D: \sea_7 x\dbsrvr. |
RDBMS Platform |
Choose IBM DB2 UDB for z/OS. |
Siebel Database Operation |
Choose Upgrade Database. The other menu choices are for database installation and administration. |
Environment Type |
- Choose Development for development environment upgrades.
- Choose Production for production and production test environment upgrades.
Upgrade Options |
Choose one of the following:
- Upgrade Siebel Database Schema (upgrep): development upgrades only
- Upgrade Siebel Database Schema (upgphys): development upgrades only
- Prepare for Production Upgrade: production upgrades only
- Upgrade Siebel Database Schema (upgrep + upgphys): production upgrades only
Siebel Industry Application |
This screen appears if you are upgrading from a Siebel Industry Solution or Siebel Industry application. Choose the application you are upgrading from. If you have upgraded to the base Siebel Business application as part of upgrading to the new Siebel Industry application release, choose Siebel Business application (HOR). |
Current Siebel Version |
Choose the application version you are upgrading from. |
Language Selection |
Upgrades with more than one language pack installed only. Choose the primary (base) language that is installed. The primary language is the language in which the data is stored in the Siebel Database that is being upgraded. |
Source Database ODBC Data Source Name |
Verify the ODBC name for connecting to the source Siebel Database for your upgrade. If it is not correct, enter the correct ODBC name. The ODBC data source must have the same name as the subsystem. When you set up the ODBC connection in DB2 Connect, use the actual subsystem name for the database alias. Windows: To find the name of your ODBC data source, navigate to Start > Settings > Control Panel > Administrative Tools > Data Source (ODBC). Click the System DNS tab to find the name of your ODBC data source. UNIX: To find the name of your ODBC data source, type:
vi $ODBCINI. |
Source Database User Name |
Enter the source user name and password for the Siebel administrator of the source database for your upgrade. NOTE: The source database user name (user ID) needs to have authorization to set CURRENT SQLID.
Source Siebel Schema Qualifier |
Enter the eight-character identifier that designates the Siebel Schema for your source database. This is also an authorization ID. The schema qualifier must start with a letter, cannot contain special characters, and must be entered in uppercase. |
Target Database ODBC Data Source Name |
Verify the ODBC name for connecting to the target Siebel Database for your upgrade. If it is not correct, enter the correct ODBC name. The ODBC data source must have the same name as the subsystem. When you set up the ODBC connection in DB2 Connect, use the actual subsystem name for the database alias. |
Target Database User Name |
Enter the target user name and password for the Siebel administrator of the target database for your upgrade. NOTE: The target database user name (user ID) needs to have authorization to set CURRENT SQLID.
Target Siebel Schema Qualifier Target Security Group ID |
Enter the following parameter values: Target Schema Qualifier. Enter the up to eight-character identifier that designates Siebel Schema for your target database. This is also an authorization ID. The schema qualifier must start with a letter, cannot contain special characters, and must be entered in uppercase. Target Security Group ID. Enter the user ID of the group to whom schema access is granted, for example, SSEROLE . |
Storage Group for Temporary Indexes Storage Control File |
Enter the following parameter values: Storage Group for Temporary Indexes. Enter the name of the storage group provided by the database administrator (the default value is SYSDEFLT ). Storage Control File. Use either of the following methods to select the storage control file that contains the previously customized database storage layout (this is the file that you prepared in Preparing the Storage Layout of the Schema):
- Windows: Accept the default value displayed in the Storage Control File field (this is the DBSRVR_ROOT\DB2390 directory. For example, D:\DBSRVR_ROOT\DB2390\storage.ctl) or use the Browse button to navigate to a different directory.
- UNIX: Enter the path to your storage control file.
Primary Quantity for Temporary Index Space |
Enter the primary and secondary quantities for temporary index space. |
DDL Commit Frequency |
Enter the DDL commit frequency for your upgrade. |
DDL Output Directory |
Accept the default or enter the directory name. NOTE: When this process is complete, this directory contains all of the files necessary to create the Siebel Database schema. These files must be manually applied by the database administrator.
Log Output Directory |
Accept the default or enter the directory name. If the directory does not exist, it will be created. Do not use special characters such as spaces, slashes, or symbols in the name of the log output. CAUTION: If you are restarting or recovering a previous incomplete upgrade, do not change the Log Output Directory that you previously selected.
