Upgrade Guide for DB2 UDB for z/OS > Upgrading a Database from the Mainframe >
Generating Development Environment Mainframe-Centric Upgrade Files
Upgrades: All upgrades. Environments: Development (mainframe-centric) environment. This topic is part of an upgrade process. See How to Perform the Upgrade. By default, the Siebel software contains the midtier-centric development environment upgrade files. If you want to perform a mainframe-centric development environment upgrade, you need to copy and replace these files in the DBSRVR directory to generate the appropriate upgrade output files. To generate development environment upgrade files to run on the mainframe
- Navigate to the
DBSRVR_ROOT \DB2390\390mainframedev directory.
- Run the runme.bat file by double-clicking on it.
The files required for the upgrade are copied to the appropriate locations as shown in Table 25.
Table 25. Upgrade Output Files
DBSRVR\DB2390
dedup.jcl |
Used for production upgrades only. |
dedup_prod.jcl |
DBSRVR\DB2390\UPGRADE\< PATH >\
driver_upgrep_dev_77_mf.ucf |
driver_upgrep_dev_752_mf.ucf |
driver_upgrep_dev_704_mf.ucf |
driver_upgrep_dev_621_mf.ucf |
SIA applications only. |
master_upgrep_dev_77_mf.ucf |
master_upgrep_dev_752_mf.ucf |
master_upgrep_dev_704_mf.ucf |
master_upgrep_dev_621_mf.ucf |
SIEBSRVR\ADMIN
dbsrvr.scm |
Windows only. |
SIEBSRVR\LOCALE\ XXX
where XXX= the language code of the language of the Database Configuration Wizard. |
dbsrvr.scl
Windows only. |
SIEBSRVR\BIN
dbsrvr_config.ksh
UNIX only. |
