Upgrade Guide for DB2 UDB for z/OS > Basic Database Preparations >
Reviewing Tablespace Size
Upgrades: All upgrades.
Environments: Development environment only.
Certain tables require larger tablespaces in Release 7.8 to accommodate additional columns. Review the tables listed in Step 16 and verify that the page size is sufficient to accommodate new columns (some of these tables may not have existed in your schema in previous releases.)
NOTE:  If the S_EMPLOYEE table existed in your schema during previous releases, you must move S_EMPLOYEE to a 16-KB bufferpool before performing an upgrade because an additional column is added to this table by the upgrade. S_EMPLOYEE has no default tablespace name, because it is obsolete.
Specify an entry in the storage control file for each obsolete table and extended table that you want to move to the 1:1:1 model. The 1:1:1 model was new in Release 7.7. For more information, see Planning Your Upgrade. It is recommended that you validate the storage control file, particularly where you have schema changes.
Drop all views (including custom views) on a table before you move it.
Table 16. Tables with Additional Columns
Table Name
Default Tablespace Name
New Page Size
S_ASSET
H0477000
16 KB
S_COLUMN
H0658000
16 KB
S_EMPLOYEE
H0997000
16 KB
S_CRSE_URL
H0738000
16 KB
S_DD_TRGT_GRP
H0875000
16 KB
S_IC_CALC_IT
H1158000
16 KB
S_PART_RPR
H1523000
16 KB
S_PERF_MGR_APPR
H1534000
16 KB
S_PROD_DEFECT
H1626000
16 KB
S_PROD_INT
H1639000
16 KB
S_SCHMST_DBSCPT
H1808000
32 KB
S_SRC_PAYMENT
H1894000
16 KB
S_SRV_REQ1_FNX
F2689000
16 KB
S_SRV_REQ1_FNXM
F2690000
16 KB
S_TABLE
H1966000
16 KB
S_UPG_KITWIZ
H2009000
16 KB
Table 17 lists the EIM tables that need to be evaluated for sufficient tablespace size.
Table 17. EIM Tables with Additional Columns
Table Name
New Page Size
EIM_ACCOUNT
H0004000
32 KB
EIM_ADDR_PER
H0019000
16 KB
EIM_AGREE_DTL
H0022000
16 KB
EIM_AGREEMENT1
H0021000
32 KB
EIM_ASSET_DTL
H0033000
16 KB
EIM_BASELN_DTL
H0041000
16 KB
EIM_CALL_LST
H0046000
32 KB
EIM_CONSUM_DTL
H0064000
16 KB
EIM_CONTACT
H0065000
32 KB
EIM_CONTACT1
H0066000
32 KB
EIM_COURSE
H0073000
32 KB
EIM_ENTLTMPL
H0121000
16 KB
EIM_FN_ASGNGRP
F2300000
16 KB
EIM_FN_PAYEE1
F2346000
16 KB
EIM_FN_PAYEE2
F2347000
16 KB
EIM_FN_REVN1
F2357000
32 KB
EIM_GROUP
H0147000
16 KB
EIM_IC_INCENTV
H0153000
16 KB
EIM_MDF_DTL
H0181000
16 KB
EIM_ORDER
H0198000
32 KB
EIM_ORDER1
H0199000
16 KB
EIM_ORDER_ITEM
H0201000
32 KB
EIM_ORDER_SHIP
H0203000
16 KB
EIM_PAYMENT
H0215000
32 KB
EIM_PAYMNT_DTL
H0216000
16 KB
EIM_PDSHIP_DTL
H0219000
16 KB
EIM_PL_ITM_DTL
H0228000
16 KB
EIM_PRODINVLOC
H0249000
16 KB
EIM_PRSP_CON
H0271000
32 KB
EIM_PT_RPR_DTL
H0276000
16 KB
EIM_QUO_IT_DTL
H0286000
16 KB
EIM_QUOTE1
H0281000
16 KB
EIM_QUOTE_IT
H0283000
32 KB
EIM_SRC1
H0301000
16 KB
EIM_SRC2
H0302000
16 KB
EIM_SRC_DBM
H0303000
16 KB
EIM_SRC_EVT
H0305000
32 KB
EIM_TARGET_DTL
H0317000
16 KB
