Using Siebel Tools > About the Siebel Tools User Interface > About the Siebel Tools Menu Bar >
Query Menu
The Query menu options allow you to create and refine Object List Editor queries, which restrict the list of objects that appear in the current Object List Editor. An option is provided that lets you change the sort order of objects in the window.
Table 9 describes the Query menu options.
Table 9. Query Menu Options
Option
(Shortcut)
Description
New Query
(CTRL+Q)
Allows you to specify restrictions on the set of objects to be displayed in the current Object List Editor.
Refine Query
(CTRL+R)
Allows you to add additional restrictions to the query currently in effect.
Execute Query
(ENTER)
Executes the query you have just specified, causing the restrictions to take effect. This has the same effect as pressing ENTER.
Sort Order
Invokes the Sort Order dialog box, for specification of sort order criteria for the list of objects in the Object List Editor.
Using Siebel Tools
