Using Siebel Tools > About the Siebel Tools User Interface > About Object Explorer >
The Detail Tab of the Object Explorer
If you select the Detail tab of the Object Explorer (as shown in Figure 5) and expand an object type, all the objects of that type appear in the Object Explorer. If you select an object type in the Detail tab, the Object List Editor displays all the objects of that type.
Figure 5. The Detail Tab of the Object Explorer Window
Using Siebel Tools
