Using Siebel Tools > Checking Out and Checking In Projects and Objects >
Viewing Locked Objects Within Projects
When the Allow Object Locking property of a project is set to TRUE, you can view any objects within the project that are locked. You can view locked objects in either the server repository or the local repository. To view locked objects
- In the Object Explorer, navigate to the Project object type.
- In the Object List Editor, select the project that contains the objects to view.
- Right-click and choose one of the following:
