Using Siebel Tools > Checking Out and Checking In Projects and Objects >
Locking Objects Locally
When a project's Allow Object Locking is set to TRUE, you can lock individual objects within the project in your local repository without having to check them out from the server.
To lock objects locally
  • Select the object, right-click, and then choose Lock Object.
Using Siebel Tools
