Using Siebel Tools > Checking Out and Checking In Projects and Objects > Limitations of Object Check Out and Check InWhen a project's Allows Object Locking property is set to TRUE, you cannot perform the following tasks on objects checked out from the server repository: |
Using Siebel Tools |
