Using Siebel Tools > Checking Out and Checking In Projects and Objects >
Viewing Object Differences
Before you check in objects, you can compare the copies stored in your local database to those stored in the server database. Siebel Tools compares the current state of the objects with the version of these objects at the time of checkout. To view differences between objects
- Choose Tools > Check In.
- In the Check In dialog box, select the project you want to compare.
- Click Diff.
The Object Comparison dialog box appears and displays the selected projects and any differences between objects in the local database and objects in the server database.
