Using Siebel Tools > Checking Out and Checking In Projects and Objects >
About the Project Check Out Dialog Box
The Check Out dialog box lists projects available for check out. It does not list individual objects within projects. Figure 13 shows an example of the Project Check Out dialog box.
Figure 13. Example Check Out Dialog Box
Click for full size image
Table 23 describes each user interface element of the dialog box.
Table 23. Project Check Out Dialog Box User Interface Elements
Element
Description
Repository drop-down list
Displays the repositories on the server. The list of projects in the projects list reflects the list of projects in the selected server repository. If you select a different server repository from the one currently open in Siebel Tools locally, a warning appears, and you must either get all projects or change the repository selection.
Projects list
Project
Displays the name of each project in the server repository.
Updated
A value of Yes appears if the server Locked By and Locked Date are different from the client version, indicating that your version of the project is out of sync with the server's version.
Server Locked By
Logon ID of the developer who currently has this project checked out on the server.
Server Locked Date
Date of check out.
Client Locked By
Logon ID of the developer who currently has this project locked locally.
Client Language
The language of the project currently locked on the client. Only one language can be locked at one time.
Allow Object Locking
A value of Yes appears if the project allows object check-in/out. The default value is Yes. If you want to restrict object check out, see Enabling Object Check Out and Check In.
Owner Branch
Displays the owner branch for each project. If the project's Owner Branch is not blank, the user's assigned Repository Branch must match in order to check out the project or any of its objects.
This column is hidden in the Object List Editor by default, but you can display it by right-clicking the Columns Displayed menu option.
Option buttons
Selected projects
When this option button is selected, you can select individual projects to check out or get.
All projects
When this option button is checked, all projects in the repository are selected to check out or get.
Updated projects
When this option button is active, only projects with an Updated value of Yes are selected. This allows you to check out or get only those projects on the server that are new or different from corresponding projects in the local repository. Normally you perform a Get to bring your local repository up to date.
Get locale specific data only check box
Checking this box gets string translations and locale-specific attributes being stored in the locale objects only. It does not get data stored in the locale object's parent object.
Buttons
Get
Selected projects are copied to the local repository, replacing pre-existing versions there, but not locking them on the server. You can get any projects on the server, including those locked by others.
Check Out
Copies all objects in the selected projects to the local repository and locks them on the server (and client).
You cannot check out projects that are currently locked on the server by another user.
Options
Opens the Development Tools Options dialog box with the Check In/Out tab selected. This is the same dialog box that appears when you choose Tools > Options.
Cancel
Cancels the check out and closes the Check Out dialog box.
Columns Displayed can be grayed out. Modes of Applet Web templates determine the kind of actions available in applets to users. The mode also determines which buttons appear in Web templates. For example, the Edit button appears in applets set to the Edit mode, but this button does not appear in applets set to Base (Read Only) mode.
Using Siebel Tools
