Using Siebel Tools > Checking Out and Checking In Projects and Objects >
Checking Out Projects from the Server Repository
When you check out projects from the server repository, the following occurs:
- All objects associated with the projects are locked on the server, preventing other developers from checking them out.
- All objects associated with the projects are copied from the server database to your local database.
- All objects associated with the projects are locked on your local database, allowing you to edit them.
NOTE: If the Allow Object Locking property is set to TRUE, you cannot check out a project from the server. You must disable object locking to check out a project from the server.
To check out projects from the server repository
- Choose Tools > Check Out.
- In the Check Out dialog box, make sure that the correct repository is selected.
- Select the projects you want to check out, then click Options.
- In the Development Tools Options dialog box, make sure the Server and Client data sources are specified correctly.
- Click OK.
The Development Tools Options dialog box closes.
- In the Check Out dialog box, click Check Out.
Objects are checked out of the server database and stored in your local database.
Related Topics
Guidelines for Check Out and Check In
About the Project Check Out Dialog Box
Setting Options for Check Out and Check In
