Using Siebel Tools > Siebel Script Editors >
About the Scripted Flag
For object types that can have a Siebel script attached to them (applet, application, and business component), there is a property in the Object List Editor called Scripted. This property indicates whether Siebel scripts are attached to the object definition. A check mark indicates the presence of scripts; no check mark indicates that the object definition has no scripts.
Using Siebel Tools
