Using Siebel Tools > Working with Projects > Creating New ProjectsYou typically create new projects to group related sets of new objects or to break large numbers of existing objects into more manageable groups. If you intend to implement a new project on the server repository, follow this development process:
For information on performing a Get, see Getting Projects from the Server Repository. For information on project check in and check out, see Checking Out and Checking In Projects and Objects. NOTE: You cannot delete projects using Siebel Tools, but you can delete projects using SQL commands. |
Using Siebel Tools |
