Using Siebel Tools > Working with Strings and Other Locale-Specific Data > Running the String Consolidation Utility > Parameters for Running Consoleapp.exe to Consolidate StringsThe parameters for running Consoleapp.exe to consolidate duplicate symbolic strings are listed in Table 44. The format is as follows: Consoleapp.exe <Config file> <app lang> <uid> <pw> <Business Service> <Method Name:Parameters> |
Using Siebel Tools |
