Siebel VB Language Reference > VB Language Overview > VB Expressions >
Comparison Operators (Numeric and String)
Operator
Comments
Greater than
Less than
Equal to
Less than or equal to
Greater than or equal to
Not equal to
For numbers, the operands are widened to the least common type (Integer is preferable to Long; Long is preferable to Single; Single is preferable to Double). For Strings, the comparison is case-sensitive, and is based on the collating sequence used by the language specified by the user using the Windows Control Panel. The result is 0 for FALSE and -1 for TRUE.
