Siebel VB Language Reference > VB Language Overview > VB Expressions >
Logical Operators
Operator
Comments
NOT
Unary Not—operand can be Integer or Long. The operation is performed bitwise (one's complement).
AND
And—operands can be Integer or Long. The operation is performed bitwise.
OR
Inclusive Or—operands can be Integer or Long. The operation is performed bitwise.
XOR
Exclusive Or—operands can be Integer or Long. The operation is performed bitwise.
EQV
Equivalence—operands can be Integer or Long. The operation is performed bitwise. (A EQV B) is the same as (NOT (A XOR B)).
IMP
Implication—operands can be Integer or Long. The operation is performed bitwise. (A IMP B) is the same as ((NOT A) OR B).
