Siebel Business Process Framework: Workflow Guide > Reference Materials for Siebel Workflow > Manipulating and Processing Data > Using the TimestampYou can use the timestamp to get the current system time and to do time arithmetic based on the current time. The arithmetic involving time information for a workflow process is different from that for a workflow policy program. The second operand of the 'Timestamp () ' function must be provided in a scale of minutes, that is, as a fraction of the whole day. For example, if the intended result of an arithmetic operation is 30 minutes, then the argument appears as described in the following syntax: The operation is explained as follows: For more information date calculations with a workflow policy, see Entering Date Calculations in the Conditions Applet. |
Siebel Business Process Framework: Workflow Guide | Copyright © 2008, Oracle. All rights reserved. | |
