Table 90. Properties of the Application Object Type
Acknowledgement Web Page |
The Web page that Siebel CRM displays after the user successfully logs in. If a login occurs after a timeout, then Siebel CRM displays the view that the user attempted to access when the timeout occurred. |
Acknowledgement Web View |
The view that Siebel CRM displays after the user successfully logs in, except in the following situations:
- Timeout. If the user logs in after a timeout, then Siebel CRM displays the view that the user attempted to access when the timeout occurred.
- Explicit login required. Assume the following occurs:
Container Web Page |
A Web page that defines the structure of the Siebel application. This page can contain the common user interface components, such as screen bars, view bars, logos, and so forth. You can use this page to define the HTML Frame definition document for the Siebel application. Siebel CRM displays all views and, as an option, all pages in the context of the container page. For more information, see About the Container Page. |
Error Web Page |
The page Siebel CRM displays if an error occurs in the Siebel application. |
Login Web Page |
The page Siebel CRM displays as the login page. |
Logoff Acknowledgement Web Page |
The page Siebel CRM displays when the user logs out of the Siebel application. |
Sort Web Page |
The page Siebel CRM uses to create a dialog to perform an advanced sort on list applet columns. |
