Configuring Siebel Business Applications > Reference Materials for Configuring Siebel Business Application > Properties of Object Types >
Properties of a Siebel Table
Table 80 describes properties that Siebel CRM commonly uses with a Siebel table.
Table 80. Properties That Siebel CRM Commonly Uses with a Siebel Table
Name |
The name of the table in the RDBMS. |
Type |
The table type. For more information, see Table 83. |
Base Table |
The base table if the table is an extension table. If the table is a base table, then this property is empty. An extension table always identifies a base table. |
User Name |
A longer, descriptive name that helps you identify the table. |
Comments |
A text description of the table, such as the type of data that Siebel CRM stores in the table. |
Status |
The current status of a table. Indicates if Siebel CRM can use, in the most recent version of Siebel CRM, a table from a previous version of Siebel CRM. |
