Implementing Siebel Business Applications on DB2 UDB for z/OS > Maintenance Considerations for z/OS > Enabling DB2 Dynamic Statement Caching > About Managing the Dynamic Statement CacheBecause DB2 uses the Environmental Descriptor Manager (EDM) component to manage the dynamic statement cache, it is important that you set EDM-related system parameters to appropriate values. Prior to DB2 for z/OS V8, the cached SQL statements were stored in either the primary EDM Pool, or in a data space. In DB2 for z/OS V8, the cached SQL statements are always stored in a dedicated area above the 2 GB bar. For guidance on setting the EDM system parameters, see your IBM documentation. NOTE: Monitor and adjust the EDM Pool and the related cache storage areas based on your workload. System parameters associated with dynamic statement caching are described in Table 14.
Implementing Siebel Business Applications on DB2 UDB for z/OS | Copyright © 2008, Oracle. All rights reserved. | |
