Siebel Pricing Administration Guide > Siebel Pricer Technical Reference > Miscellaneous Pricing Workflows >
PSP Waterfall Synch to DB Workflow
This workflow writes waterfall records to the database according to input from the data map object.
Figure 22. PSP Waterfall Synch to DB Workflow
Click for full size image
Table 24 lists describes the step in the PSP Waterfall Synch to DB Workflow workflow with the business service and method that is called.
Table 24. Steps of the PSP Waterfall Synch to DB Workflow
Name
Type
Business Service
Method
Sub Process
Description
Sync Waterfall
Business Service
PSP Waterfall Service
WriteWaterfall
Writes waterfall records to database.
Siebel Pricing Administration Guide Copyright © 2006, Oracle. All rights reserved.
