Siebel Pricing Administration Guide > Siebel Pricer Technical Reference > Pricing Procedures and Workflow References >
Pricing Procedure - Calculate Net Price Workflow
The Pricing Procedure - Calculate Net Price workflow is responsible for the net price calculation, which takes into account volume discount, aggregate discount sequence, product promotion, manual adjustment and minimum/maximum price bound checks.
Figure 18. Pricing Procedure - Calculate Net Price Workflow Process
Workflow Description. This workflow does the following:
  1. Initializes the net price value as the start price value.
  2. Queries in FS Product Price Item Details Buscomp for any covered asset service pricing adjustment.
  3. Moves those rows with the Exclude Pricing flag set to another the Keep Price Row Set row set. This will skip all system-generated discounts throughout the procedure.
  4. Applies a manual adjustment (discount amount, discount percentage, discount price and header discount percentage) for the row set with Exclude Pricing flag Set.
  5. Sets the pricing adjustment that indicates the total amount of system-generated discount accounts for the row set with Exclude Pricing flag = Y.
  6. Evaluates simple and tiered volume discount. This would also populate the next discount and upsell message for upsell purposes.
  7. Evaluates product promotion discounts.
  8. Calls the Pricing Procedure - Bundle Discount subprocedure to evaluate the aggregate discount sequence.
  9. Checks if the current net price is within the boundary of the minimum and maximum price.
  10. Applies a manual adjustment (discount amount, discount percentage, discount price and header discount percentage).
  11. Sets the pricing adjustment that indicates the total amount of system-generated discount accounts.
  12. Merges the two row sets generated from the Keep Price = Y? back into one row set.
Table 20 lists the steps of the Pricing Procedure - Calculate Net Price workflow with the business service and method that is called by each.
Table 20. Steps of the Pricing Procedure - Calculate Net Price Workflow
Name
Type
Business Service
Method
Sub Process
Description
Net = Start
Business Service
Row Set Transformation Toolkit Service
Conditional Action Transform
Initializes the Net Price value as the Start Price value.
Calculate Covered Asset Service Price
Business Service
Simple Look-Up Transform
Keep Price = Y?
Business Service
Split Transform
Moves those rows with Exclude Pricing Flag set to another row set, the Keep Price Row Set row set. For these, all system-generated discounts will be skipped throughout the procedure.
Manual Adjustment for Keep Price = Y
Business Service
Applies Manual Adjustment for Keep Price Row Set row set.
Set Pricing Adj for Keep Price = Y
Business Service
Sets the Pricing Adjustment that indicates the total amount of system-generated discounts for the Keep Price Row Set row set.
Simple Volume Discount
Business Service
Evaluates Simple Volume Discount.
Simple Volume Discount Upsell
Business Service
Populates Simple Volume Discount Upsell information.
Tiered Volume Discount
Business Service
Evaluates Tiered Volume Discount.
Tiered Volume Discount Upsell
Business Service
Populates Tiered Volume Discount Upsell information.
Look-Up Promotion Discount
Business Service
Checks whether a promotion discount is defined.
Apply Promotion Discount
Business Service
Applies the Promotion Discount found in the previous step.
Apply Bundle Discounts
Sub Process
Pricing Procedure - Aggregate Discounts
Invokes a subprocedure for calculating Aggregate Sequence.
Check Min/Max Price
Business Service
Ensures that the net price is within the minimum and maximum defined in the price list item.
Manual Adjustment
Business Service
Applies manual adjustment.
Set Pricing Adjustment
Business Service
Sets the pricing adjustment, which is the total amount of system- generated discounts.
Merge Keep Price = Y
Business Service
Merge Transform
Merges back the Keep Price Row Set row set.
Siebel Pricing Administration Guide Copyright © 2006, Oracle. All rights reserved.
