Siebel Product Administration Guide >
What's New in This Release
What's New in Siebel Product Administration Guide, Version 8.0 Rev B.
Table 1 lists changes described in this version of the documentation to support release 8.0 of the software.
Table 1. New Product Features in Siebel Product Administration Guide, Version 8.0 Rev B
Topic
Description
Deleting Product Records
New topic. It describes how to deactivate product records.
Deleting a Product Class
New topic. It describes how to deactivate product class records
Enabling the Quick Edit Feature for Siebel Configurator
Modified topic. It includes additional tasks needed to enable quick edit.
Using User-Defined UI Properties
New topic. It describes how to use user defined UI properties in JavaScript.
Defining a UI Property
Modified topic. It includes new information about using an attribute value from a line item integration component.
Creating a Context Variable Link
New topic. It describes how to create a context variable link.
Cfg_InstInitialize Event
Modified topic. It adds more information about how this event is triggered.
Deleting Product Versions
New topic. It describes how to delete product versions.
Defining How Eligibility Output Displays
Modified topic. It adds information about how to define how eligibility output displays on server-based applications.
Operating System Environment Variables Used with Siebel Configurator
Modified topic. It adds information about which server the environment variable is on when you use remote Siebel Configurator.
GetConditionVal Method
New topic. It describes the GetConditionVal method.
ReplaceItem Method
New topic. It describes the ReplaceItem method.
What's New in Siebel Product Administration Guide, Version 8.0 Rev A.
Table 2 lists changes described in this version of the documentation to support release 8.0 of the software.
Table 2. New Product Features in Siebel Product Administration Guide, Version 8.0 Rev A
Topic
Description
About Themes for the Siebel Configurator UI
Modified topic. Added brief descriptions of multiselect and of quick edit theme to the list of base themes.
New topic. Feature introduced in Siebel 8.0.0.9.
Siebel Configurator UI Properties
Deleted topic from Siebel Configurator UI Properties. Moved information about hiding parts of a customizable product to About Predefined UI Properties.
Creating Dynamic Siebel Configurator User Interface Controls
Set Preference Template
Modified topic. Added information about dynamic default, a feature introduced in Siebel 8.0.0.9.
About Product Path in Siebel Configurator Scripts
Modified topic. Added information about enhancements to product path.
SetAttribute Method
Modified topic. It describes minor changes in this topic.
GetAttribute Method
BatchRequest Method
About Pre-Pick Compatibility
Enabling Pre-Pick Compatibility
What's New in Siebel Product Administration Guide, Version 8.0.
Table 3 lists changes described in this version of the documentation to support release 8.0 of the software.
Table 3. New Product Features in Siebel Product Administration Guide, Version 8.0
Topic
Description
Enabling the Multiselect Feature for Siebel Configurator
New topic. It describes the new multiselect feature for Siebel Configurator.
Creating a Business Component Configuration Link
Modified topic. It has added information about creating context-based link items.
Procedural Condition Templates
New topics. They describe how to use the two new Configuration Constraint templates: Procedural-Condition Check and Set Procedural Conditional Variable.
Migrating Products Using Application Deployment Manager (ADM)
Modified topic. Information is available in Siebel Application Deployment Manager Guide. This topic now just refers readers to that document.
Defining Eligibility for Product Attributes
New topic. It describes defining the eligibility for product attributes.
New topic. It contains information about the operating system environment variables.
GetLinkedItemValues Method
New topic. It describes the GetLinkedItemsValues method.
SetLinkItemValues Method
New topic. It describes the SetLinkItemValues method.
SetUIOption Method
New topic. It describes the SetUIOption method.
Siebel Product Administration Guide Copyright © 2010, Oracle and/or its affiliates. All rights reserved. Legal Notices.
