Siebel Product Administration Guide > Product and Promotion Eligibility and Compatibility > Eligibility and Compatibility Workflow Reference > Compatibility Multiple Popup WorkflowCompatibility Multiple Popup Workflow is responsible for displaying product compatibility violations determined by the Eligibility and Compatibility workflows. This popup gives the user the option of adding the incompatible product or removing them. The popup gets triggered in Quotes and Orders unless the Skip Quote flag is set to N. This workflow is shown in Figure 15. Workflow Description. This workflow does the following:
Siebel Product Administration Guide | Copyright © 2010, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
