Siebel Product Administration Guide > Creating Custom Siebel Configurator User Interfaces > Process of Creating a Custom Siebel Configurator User Interface > Assigning Siebel Configurator Interfaces to UsersAfter you have created custom user interfaces for all your users, you must assign each interface to the appropriate users. This task is a step in Process of Creating a Custom Siebel Configurator User Interface. You can create a number of Siebel Configurator user interfaces for the same customizable product and assign them to different users. This can be useful for the following reasons:
Because several user interfaces use the same product model, maintenance is reduced. You assign a user interface to users by associating it with a responsibility. Users have responsibilities that determine what views they can see. If you set up your system for the first example above, you would have the responsibilities Web Customers and Call Center Agents. For the second example above, you would have the responsibilities Salesperson and Technical Designer. For more information about responsibilities, see Siebel Security Guide. If you leave the responsibility blank, the user interface is assigned to all users. If you add another option with a specific responsibility to override the blank responsibility for some users, you should make the sequence number for this specific responsibility lower than the sequence number for the blank responsibility. You can also control the UI option using SetUIOption Method. To assign a Siebel Configurator user interface to users
Siebel Product Administration Guide | Copyright © 2010, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
