Siebel Product Administration Guide > Configuration Constraints > About Managing Configuration Constraints > Editing Configuration ConstraintsIn the Constraints List, you cannot edit the definition of the constraint in the Constraint column. To edit the definition, you must display the constraint in the Constraint Statement form, make your changes, and save the constraint. When you save the constraint, you can overwrite the constraint with the changes or save the changes as a new constraint. The following procedure explains how to edit a constraint definition and overwrite the constraint with the changes.
Siebel Product Administration Guide | Copyright © 2010, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
