Siebel Product Administration Guide > Configuration Constraints > About Managing Configuration Constraints > Copying Configuration ConstraintsWhen you copy a constraint, the system creates an exact duplicate of the constraint and displays it in the Constraints view. You can then edit the constraint definition as desired. If you copy a constraint and make no changes to the copy, two exactly equivalent constraints are used to compute each solution. This does not cause a problem, and solutions are computed as if there was only one constraint. Use the copy feature to create groups of constraints that are similar. Start by creating the basic constraint. Then copy it once for each constraint in the group. Finally, edit the copies to create the constraints in the group.
Siebel Product Administration Guide | Copyright © 2010, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
