Siebel Product Administration Guide > Configuration Constraints > About Managing Configuration Constraints >
Deleting Configuration Constraints
Deleting a constraint removes it from the customizable product. The template on which the constraint was based is not removed and remains available.
To delete a constraint
  1. Navigate to the Administration - Product screen.
  2. Select and lock the desired customizable product or product class.
  3. Navigate to the Constraints view.
  4. In the Constraints List, select the constraint you want to delete.
  5. From the Constraints List menu, select Delete Record, and click OK when asked if you want to delete the record.
  6. From the Constraints List menu, select Validate.
    This starts a configuration session. Verify that the customizable product constraints function correctly.
Siebel Product Administration Guide Copyright © 2010, Oracle and/or its affiliates. All rights reserved. Legal Notices.
