Siebel Product Administration Guide > Siebel Configurator Technical Reference > Specifying Keep Alive Time for Siebel Configurator SessionsBy default, product configuration sessions remain active indefinitely. They do not time out. You can specify how long product configuration sessions remain active by setting the server parameter for Keep Alive Time. This parameter specifies the time in seconds that a session can remain idle before the session is timed out. The default value of -1 means that the session can remain idle indefinitely and will not be timed out. Table 47 shows this server parameter. |
Siebel Product Administration Guide | Copyright © 2010, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
