Table 9. Parameters That Must Be Reencrypted After Increasing the Encryption Level
To Reencrypt the Parameter |
ApplicationPassword |
This parameter is defined for named subsystems of type InfraSecAdpt_LDAP [the default names are LDAPSecAdpt and ADSISecAdpt]. This parameter is set if LDAP or ADSI security adapter authentication is used. |
Siebel Web Clients can use the Server Manager command. Siebel Mobile Web Clients or Developer Web Clients must edit the appropriate application configuration file. |
CRC CustomSecAdpt_CRC DBSecAdpt_CRC |
These parameter are defined for named subsystems of type InfraSecAdpt_DB, InfraSecAdpt_LDAP, or InfraSecAdpt_Custom. These parameters specify the checksum validation value for the security adapter DLL file and are set for LDAP, ADSI, database, and custom security adapters. For further information on checksum validation, see Configuring Checksum Validation. |
ClientDBAPwd |
This parameter is specified for the Database Extract server component. |
Use the Server Manager command. |
DSPassword |
This parameter is defined for named subsystems of type InfraDataSource (it can be set for the ServerDataSrc named subsystem, or another data source). It is specified for database security adapter authentication. |
DSPrivUserPass PrivUserPass |
These parameters are specified for the Generate Triggers Siebel Server component. |
DbaPwd NewDbaPwd |
These parameters are specified for the Generate New Database Siebel Server component used with Siebel Remote. |
Use the Server Manager command. For information on changing these parameters, see Siebel Remote and Replication Manager Administration Guide |
MailPassword |
This parameter is set for the email account that Siebel Email Response uses to connect to the SMTP/POP3 server. |
Use the Siebel user interface. Navigate to Administration - Communications, Communications Drivers and Profiles, and then the Internet SMTP/POP3 Server screen. |
Password |
This parameter, set at the Siebel Enterprise level, is the password for the system user (for example, SADMIN) specified by the Username parameter. It is recommended that you do not change the value for this parameter when you reencrypt it. |
SAPRfcPassword |
This parameter specifies the SAP password used with Oracle's Siebel Connector for SAP R/3. |
Edit the tools.cfg file. Edit the [SAPSubsys] section of the appropriate application configuration file if using a Siebel Mobile Web Client. See Siebel Connector for SAP R/3 for additional information on changing this parameter. |
TableOwnPass |
This parameter specifies the password for the Database Table Owner (DBO) account, which is used to modify the Siebel database tables. |
Siebel Web Clients can use the Server Manager command. Siebel Developer Web Clients must edit the appropriate application configuration file. Change the parameter in the Siebel database. See Changing the Table Owner (DBO) Password for instructions. |
TrustToken CustomSecAdpt_TrustToken |
These parameters apply in a Web SSO environment only, and are defined for named subsystems of type InfraSecAdpt_LDAP and InfraSecAdpt_Custom. These parameters are also specified for the SWSE; the setting must be the same on both the SWSE and the security adapter. |
Siebel Web Clients can use the Server Manager command. Siebel Mobile Web Clients or Developer Web Clients must edit the appropriate application configuration file. Edit the eapps.cfg file for SWSE. |
