Siebel Database Upgrade Guide for DB2 UDB for z/OS > Planning A Siebel Database Upgrade >
About Estimating Database Size
Database upgrade is resource intensive. If the upgrade exceeds available resources, the upgrade halts. You must then resolve resource issues before resuming the upgrade.
To help you estimate the database size required when upgrading to release 8.0, Table 7 shows the number of tables in 4-KB, 16-KB, and 32-KB table spaces in a sample SIA database in a 7.0.x, 7.5.x and a 7.8 release. Table 7 also shows the space required by the tables.
Because Siebel has adopted a 1:1:1 database schema structure since release 7.7 (one table in each table space, one table space in each database), these releases require many more 16-KB and 32-KB table spaces than pre 7.7 releases. However, some tables may not require 16-KB and 32-KB table spaces if you convert LONG VARCHAR columns to CLOB columns.
Actual expected growth may also vary widely from these estimates, depending on which Siebel application you are using (Siebel Business Applications or Siebel Industry Applications), database configuration, row size of tables, data content, and code page. The number of tables and space estimates shown in Table 7 for Release 8.0 are for an EBCDIC database.
Table 7. Number of Tables and Space Required in a Sample Siebel DB2 Database by Release
Release...
4-KB table space
8-KB table space
16-KB table space
32-KB table space
8.0
4229 (2,759,008 KB)
331 (312,112 KB)
171 (62,272 KB)
105 (52,160 KB)
7.8
3857 (569,442 KB)
N/A
459 (237,735 KB)
86 (224,62 KB)
7.5.x
2542 (637,706 KB)
N/A
404 (336,384 KB)
22 (143,28 KB)
7.0.x
1995 (398,068 KB)
N/A
357 (135,469 KB)
10 (102,39 KB)
NOTE:  Table 7 shows the space required by the tables in a release but does not include the space required by indexes.
Siebel Database Upgrade Guide for DB2 UDB for z/OS Copyright © 2012, Oracle and/or its affiliates. All rights reserved. Legal Notices.
