Siebel Database Upgrade Guide for DB2 UDB for z/OS > Postupgrade Tasks for Siebel Database and File System >
Updating File System Attachments
Upgrades: All upgrades.
Environments: All environments.
This topic is part of an upgrade process. See How to Perform a Siebel Database Upgrade.
Since Siebel 7.5, file names of attachments include the attachment table name. If an upgrade migrates the records in an attachment table to a new attachment table, you must run a utility to update the file system attachment names.
Perform the tasks in the sections below to update Siebel File System attachments.
Updating Attachment File Names
The task in this section applies to all upgrades.
Oracle provides a utility to update attachment file names in the Siebel File system. Table 24 lists the input table names to use when you run the utility. The utility updates all files containing the table names you specify.
For example, if you specify the tables S_OLDTABLE_ATT and S_NEWTABLE_ATT, the utility updates the files system attachments by copying all attachment files containing the string S_OLDTABLE_ATT to attachment files containing the string S_NEWTABLE_ATT.
Table 24. Input Arguments for the Update Utility
Upgrade Path
Old Table
New Table
Upgrades: Release 6.2.1 only.
  • S_EMPLOYEE_ATT
  • S_CONTACT_ATT
  • S_ORG_INT_ATT
  • S_ACCNT_ATT
  • Upgrades from: Siebel 6.2.1 FINS.
  • Upgrades from: Siebel 7.0.x, 7.5.x, 7.7.x, & 7.8.x. Siebel Insurance only.
  • S_INSCLM_BL_ATT
  • S_INVOICE_ATT
To update file system attachments
  1. Navigate to the following directory:
    Windows: SIEBEL_ROOT\bin
    UNIX: $SIEBEL_ROOT/bin
  2. Run the following utility:
    Windows: chng_file_sys.bat OLD_TABLE NEW_TABLE "FILE_SYSTEM"
    UNIX: chng_file_sys.ksh -s OLD_TABLE -t NEW_TABLE -f "FILE_SYSTEM"
    where:
    • OLD_TABLE = The name of the attachment table in the release you are upgrading from. This table is obsolete in the new release.
    • NEW_TABLE = Attachment records in OLD_TABLE were migrated to NEW_TABLE in the new release. The utility copies file system attachments containing the string OLD_TABLE to attachments containing the string NEW_TABLE.
    • "FILE_SYSTEM" = name of the directory where the Siebel File System attachments reside (entered inside quotation marks)
      Windows example:
    chng_file_sys.bat S_EMPLOYEE_ATT S_CONTACT_ATT
    "C:\siebfile\att"
    UNIX example:
    chng_file_sys.ksh -s S_EMPLOYEE_ATT -t S_CONTACT_ATT
    -f
    "/usr/siebel/siebfile/att"
  3. Review renamed files carefully to verify that they can be accessed by Siebel Business Applications.
    For example, since S_EMPLOYEE_ATT is migrated to S_CONTACT_ATT, verify that files such as S_EMPLOYEE_12-1ABC.SAF are renamed to S_CONTACT_12-1ABC.SAF.
Updating Attachments for S_LIT
Perform the task in this section if you are upgrading from Siebel 7.0.x.
At Siebel 7.5, the records in S_LIT are migrated to S_CB_ASSET_VER. You must update the related file names of attachments from S_LIT*SAF to S_CB_ASSET_VER*.SAF.
To update attachments for S_LIT
  2. Enter the following command:
    Windows: file_upg_mm.bat ODBC_SOURCE USER_NAME PASSWORD TABLE_OWNER "FILE_SYSTEM_LOCATION" "SIEBEL_ROOT" "DBSRVR_ROOT"
    UNIX: file_upg_mm.ksh ODBC_SOURCE USER_NAME PASSWORD TABLE_OWNER FILE_SYSTEM_LOCATION $SIEBEL_ROOT DBSRVR_ROOT
    where:
    • ODBC_SOURCE = the ODBC source of the database
    • USER_NAME = the database user name
    • PASSWORD = the password for the database user name
    • TABLE_OWNER = the database tableowner
    • FILE_SYSTEM_LOCATION = the directory where the file system resides
    • SIEBEL_ROOT = the directory where the Siebel Server is installed
    • DBSRVR_ROOT = the directory where Siebel Database Server files are installed
      Windows example:
    file_upg_mm.bat SEBL sadmin sadminpw SIEBEL "C:\siebfile" "C:\sba80\siebsrvr" "C:\sba80\dbsrvr"
    UNIX example:
    file_upg_mm.ksh SEBL sadmin sadminpw SIEBEL /usr/siebel/siebfile $SIEBEL_ROOT
    /usr/siebel/dbsrvr
    Note that the UNIX syntax does not use quotes around FILE_SYSTEM_LOCATION, and DBSRVR_ROOT.
  3. Review the renamed files carefully to verify that they can be accessed by Siebel Business Applications.
Siebel Database Upgrade Guide for DB2 UDB for z/OS Copyright © 2012, Oracle and/or its affiliates. All rights reserved. Legal Notices.
