Implementing Siebel eBusiness Applications on DB2 UDB for z/OS and OS/390 > Maintenance Considerations for zSeries >
About Siebel Dynamic SQL
Traditional applications are typically based on static, hard-coded SQL. However, Siebel eBusiness Applications generate dynamic SQL statements at run time, using the Siebel Application Object Manager and the program configuration in use by the customer. In this way, SQL statements can be as individual as the deployments in which they occur and, in some cases, dynamic SQL might become so complex, that it pushes the limits of DB2. For example, joins with 30-40 tables are not uncommon.
To reduce the complexity of generated SQL (such as the number of joins, the number of columns in SELECT statements, or the number of tables in FROM statements), consider eliminating columns from the standard Siebel applets that you do not require for your business needs, especially in the most frequently used screens and views. You should also keep this consideration in mind when you customize the Siebel application by creating new objects.
