Implementing Siebel eBusiness Applications on DB2 UDB for z/OS and OS/390 > Maintenance Considerations for zSeries > About Siebel Dynamic SQL > Enabling ODBC TracingODBC tracing can be enabled by following the instructions in FAQ 1343 on Siebel SupportWeb. ODBC tracing produces results similar to the CLI trace but it focuses more on the ODBC API calls. You will not be able to see the data being passed in the SQLExecute calls with the ODBC trace but you can see it in the DB2 CLI traces. |
Implementing Siebel eBusiness Applications on DB2 UDB for z/OS and OS/390 |
