Implementing Siebel eBusiness Applications on DB2 UDB for z/OS and OS/390 > Maintenance Considerations for zSeries > About Siebel Dynamic SQL > About SQL Tracing on the DB2 Host Using Tools Like DB2 Performance MonitorTracing on the DB2 host should be set in conjunction with the DBA. Refer to the documentation for the performance monitoring tool being used to determine how to enable the tracing. |
Implementing Siebel eBusiness Applications on DB2 UDB for z/OS and OS/390 |
