Product Administration Guide > Configuration Rule Assembly Language >
Customizable Product Access Operators
Customizable Product access operators, shown in Table 46, allow you to obtain information about other areas of the customizable product. For example, you can obtain the name of an item's parent.
Table 46.  Customizable Product Access Operators
Operator
Syntax
Properties
Product root
root()
Result is root of the customizable product. Takes no arguments.
