Product Administration Guide > Configuration Rule Assembly Language >
Data Operators
Use the following operators, shown in Table 36, when working with Siebel data types.
Table 36.  Siebel Data Operators
Operator
Syntax
Properties
Number
Number(A)
Converts the operand to a number. Operand can be an expression.
String
String(A)
Converts the operand to a string. Operand can be an expression.
Date
Date(A)
Converts string to a date. Operand can be an expression.
Time
Time(A)
Converts the operand to a time. Operand can be an expression.
UtcDateTime
UtcDateTime(A)
Converts the operand to the UTC date and time. Operand can be an expression.
DateTime
DateTime(A)
Converts the operand to a date and time. Operand can be an expression. Not recommended for use. Use UtcDateTime instead.
Currency
Currency(A)
Converts the operand to currency. Operand can be an expression.
Phone
Phone(A)
Converts the operand to a phone number. Operand cannot be an expression. Can be used only with Equals (==) and Not Equal To (!=) operators to compare two phone numbers.
