Product Administration Guide > Release and Manage Customizable Products > Turning Off a Class-Product TemplateWhen you turn off a class-product template, all its inherited features are removed from the members of its product class. The class-product's structure no longer appears in the Product UI Designer or in validation mode for members of the class. Turning off a class-product template is very similar in its effect to deleting an attribute at the class level. UI groups are not affected when you turn off a class-product template. For members of the class, if you have added items to a UI group from a class-product template, you must manually remove them. To turn off a class-product template
Product Administration Guide |
