Product Administration Guide > Customizable Product Rule Designer > Creating Groups of Related RulesRelated rules are those that have the same basic construction but differ only in content. For example, you need to create a dozen exclude rules of the form Product A excludes Product B. For each rule the products will be different, but the basic construction is the same. There are several processes you can use to create groups of related rules. In the following example, you are going to create twelve exclude rules. Here are the processes you can use to create them:
Product Administration Guide |
