Bookshelf Home | Contents | Index | Search | PDF |
Product Administration Guide > Multilingual Data >
Translating the Product Description
Use this procedure to translate the product description.
To translate the product description
- Navigate to Product Administration.
- Select a product whose description you want to translate.
- From the More Info Show menu, choose Translations.
The languages list appears. If you have not selected any languages, the list is empty.
- Add a new record.
- Click in the new record's Code field and select a language code from the Language Name dialog box.
The record is updated with the language name and language code.
- Enter the translation of the description in the Description field, and then click Save.
A new record, containing the translation appears in the languages list.
Product Administration Guide Published: 23 June 2003 |
