Product Administration Guide > Multilingual Data >
Translating a Class Display Name
Use this procedure to translate the display name for the product class.
To translate a class display name
  1. Navigate to Application Administration > Class Administration.
  2. Select the product class display name you want to translate.
  3. Click the Class Translations tab.
  4. In the Class Translations tab, click New.
  5. A new record appears.
  6. Click in the new record's Code field and select a language code from the Language Name dialog box.
  7. The record is updated with the language name and language code.
  8. Enter the translation of the display name in the Display Name field, and then click Save.
  9. The record is updated and displays the translation of the class display name.
  10. Repeat these steps to create additional language translations for the class display name.
 Published: 23 June 2003
