Bookshelf Home | Contents | Index | Search | PDF |
Product Administration Guide > Technical Reference > eConfigurator API >
Object Broker Methods
The methods in this section call the Cfg Object Broker business service, which functions as a wrapper for the Object Broker.
GetProdStruct
This method returns the full structure of the customizable product.
Input Arguments:
- RootId—the unique identifier of the complex object root. If provided, RootName, Vendor, and Org are ignored. If not provided, RootName, Vendor, and Org are used to uniquely identify the product.
- RootName—the root product name. Optionally, you can use Name together with Vendor and Org to uniquely identify a product.
- (Optional) Version—version arguments are used only when testing a customizable product version that is different from the currently released version. Specify 0 to return the work space.
- (Optional) Vendor—use with RootName to uniquely identify the product. By default, this is empty.
- (Optional) Org—use with RootName to uniquely identify the product. By default, this is empty.
- Full—Yes returns the full product structure. Blank or No returns the first level of the product.
Output Arguments:
<ProdStruct> RootId
<ProdId> Name ClassId
<Port> Name ClassName ClassId OrigId Type MinCard MaxCard DefltCard LocalType InternalType
<Subobject Id/>
</port>
<Attribute> Name
<Domain Value />
</Attribute>
</ProdId>
</ProdStruct>
DeltaQuote
This method performs a recursive tree comparison of two property sets to determine the difference between them based on supplied criteria. It returns a copy of the destination product instance, marked up to indicate changes. This preconfigured API is called from an external service only in SIS Order Management, which is the only way to see this API function for the API Discovery.
In one example, you start with a computer that has one hard drive and a 900 MHz processor. You upgrade it to add a second hard drive (quantity now = 2) and replace the processor with a 1000 MHz model. The result would be one existing hard drive, one new hard drive (the instance is split), one 900 MHz CPU removed, and one new 1000 MHz CPU.
If the output property set is empty and no error code is thrown, the most likely cause is that the instances were not recognized. Check the RootId parameters and the indenting of your source and destination SiebelMessages.
Input Arguments:
- SrcRootId—the root ID for the product in the source of the comparison. This is the "before" property set.
- DestRootId—the root ID for the product in the destination of the comparison. This is the "after" property set.
- DeltaSrcField—the Path field in the source instance.
- DeltaDestField—the Path field in the destination instance.
- SrcItemIntComp—the name of the integration component for the items in the source instance (for example, Quote Item).
- DestItemIntComp—the name of the integration component for the items in the destination instance (for example, Quote Item).
- SrcXAIntComp—the name of the integration component for the XA in the source instance (for example, Quote Item XA).
- DestXAIntComp—the name of the integration component for the XA in the destination instance (for example, Quote Item XA.)
- ITEM_MAPPING—This is a property set with type= "ITEM_MAPPING." It contains a list of those fields that should be copied when creating a new instance of an item in the destination property set. The property names are the fields in the source instance, and the property values are the names in the destination instance. Here is an example output from the API sniffers:
CHILD PROPERTY SET 3
Type: ITEM_MAPPING Value:
Unit Price = Unit Price
Action Code = Action Code
Root Id = Root Id
Port Item Id = Port Item Id
Integration Id = Integration Id
Discount Amount = Discount Amount
Parent Id = Parent Id
Product Id = Product Id
Prod Item Id = Prod Item Id
Quantity = Quantity- XA_MAPPING—This is a property set with type= "XA_MAPPING." It contains a list of those fields that should be copied for each of the attributes when creating a new instance of an item in the destination property set. The property names are the fields in the source instance, and the property values are the names in the destination instance. Here is an example output from the API sniffers:
CHILD PROPERTY SET 2
Type: XA_MAPPING Value:
Value = Value
Read Only = Read Only
Name = Name
Property Type Code = Property Type Code
XA Id = XA Id- ITEM_COMPARE—This is a property set with type= "ITEM_COMPARE." It defines what constitutes a unique instance of an item in the source and destination instances. For the service, it answers the question "How do I know if these two things are the same?" Here is an example output from the API sniffers:
CHILD PROPERTY SET 1
Type: ITEM_COMPARE Value:
Product Id = Product Id- XA_COMPARE—This is a property set with type= "XA_COMPARE." It defines what constitutes a unique instance of an attribute in the source and destination instances. For the service, it answers the question "How do I know if these two things are the same?" Here is an example output from the API sniffers:
CHILD PROPERTY SET 0
Type: XA_COMPARE Value:
Value = Value
Name = Name
XA Id = XA Id- SrcInst—This is the Source Instance ("before") that will be used in the delta comparison. It is a double-indented SiebelMessage with a type of SrcInst. The top section of the output from the API sniffers is shown below for reference. Note the indenting of the SiebelMessage.
CHILD PROPERTY SET 4
Type: SrcInst Value:
Type: Value:
Type: SiebelMessage Value:
MessageId = 1-12949
IntObjectFormat = Siebel Hierarchical
MessageType = Integration Object
IntObjectName = CX Product Validation
Type: ListOfCX Product Validation Value:
Type: Product Header Value:
Name = 1-12950
Price List Id = 1-ZEC
Id = 1-12951
Type: ListOfProduct Item Value:
Type: Product Item Value:
Action Code = Existing
Port Item Id =
Integration Id = 1-12744
Cfg Type = eConfigurator
Name = System Chassis
Product Id = 1-1M9Y
Prod Item Id = null
Quantity = 1.0
Id = 1-12744- DestInst—This is the Destination Instance ("after") that will be used in the delta comparison. It is a double-indented SiebelMessage with a type of DestInst. The top section of the output from the API sniffers is shown below for reference. Note the indenting of the SiebelMessage.
CHILD PROPERTY SET 5
Type: DestInst Value:
Type: Value:
MessageId = 123
Name = 1-12950
Id = 1-12951
Has Generics Flag = Y
Port Item Id =
Sequence Number =
Product Id = 1-1M9Y
Quantity = 1.0
Prod Item Id = null
Id = 1-12744Output Arguments:
The destination instance is returned as a SiebelMessage, modified and marked up with status information. The status (new, modified, existing, removed) is indicated in the Action Code field of each item and attribute.
Product Administration Guide Published: 23 June 2003 |
