Upgrade Guide for UNIX > Postupgrade Tasks > Additional Postupgrade Tasks for Specific Applications >
Postupgrade Tasks for Enterprise Application Integration (eAI)
CAUTION:  This procedure only applies to development environment upgrades. For production environment upgrades, skip this procedure and proceed to Postupgrade Tasks for Siebel Financial Services.
If you use Enterprise Application Integration (EAI), perform the following procedure to update the definitions of the Business Objects to account for changes in data type, length, edit format or other properties during upgrading to a new version of Siebel Applications.
To upgrade integration objects
  1. Synchronize the integration objects.
  2. Validate the integration objects.
  3. If you receive validation errors, inactive the user keys or fields that cause the error.
  4. If you receive the error "List Of" in the XML Parent Element, manually remove the value "List Of" from the XML Parent Element.
 Published: 20 October 2003
