Bookshelf Home | Contents | Index | Search | PDF |
This chapter describes the tasks that must be performed after you perform an upgrade of either your development environment or your production environment. To better understand which phase of the upgrade process you are in and what tasks still remain, refer to Figure 7. Figure 7 illustrates where you are in the upgrade process depending on whether you are performing a development or production environment upgrade.
NOTE: If a procedure is specific to one environment, a caution appears at the beginning of the procedure; for example, CAUTION: This procedure only applies to development environment upgrades.
A checklist of postupgrade tasks is provided in Table 17. Perform the procedures for the environment you are upgrading.
Upgrade Guide for UNIX Published: 20 October 2003 |
