Upgrade Guide for UNIX > Postupgrade Tasks >
Postupgrade Tasks for All Environments
Perform the postupgrade procedures that apply to the environment you are upgrading—development or production.
Review the checklist of postupgrade tasks in Table 17 to determine what tasks you need to perform.
Table 17.   Postupgrade Tasks
Environment
Postupgrade Tasks
Dev.
Prod.
  1. Drop DB2 8-KB tablespaces and buffers. See Dropping DB2 8-KB Tablespaces and Buffers.
4
4
  1. Manually archive the log files. See Manually Archiving the Log Files.
4
4
  1. Update file system directory. See Updating the File System Directory.
4
4
  1. Update file system attachments. See Updating File System Attachments.
4
4
  1. Migrate custom columns on obsolete tables. See Migrating Custom Columns on Obsolete Tables.
4
  1. Run update statements. See Running Update Statements.
4
4
  1. Reapply custom extensions and foreign key columns on obsolete tables. See Reapplying Custom Extensions and FK Columns on Obsolete Tables.
4
  1. Migrate custom business components and resolve business component and join conflicts. See Migrating Custom Business Components and Resolving Conflicts.
4
  1. Identify Obsolete Objects. (Optional) See Identifying Obsolete Objects.
4
  1. Generate reporting relationships. See Generating Reporting Relationships.
4
4
  1. Set visibility modes for access control. See Setting Visibility Modes for Access Control.
4
  1. Resolve duplicate EIM mappings. See Resolving Duplicate EIM Mappings.
4
  1. Safeguard the Custom Repository export file. See Safeguarding the New Custom Repository Export File.
4
  1. Produce a new custom configuration file. See Producing a New Custom Configuration File.
4
  1. Regenerate the database template file. See Regenerating the Database Template File.
4
  1. Extract Developers or Siebel Tools Clients. See Extracting Developers or Siebel Tools Clients.
4
  1. Test the Upgraded Configuration. See Testing the Upgraded Configuration.
4
  1. Validate dock objects and rule definitions. See Validating Dock Objects and Rule Definitions.
4
4
  1. Run statistics. See Running Statistics.
4
4
  1. Reorganize the P1 index for DB2 UDB. See Reorganizing the P1 Index for DB2 UDB.
4
4
  1. Reset database server configuration parameters. See Resetting Database Server Configuration Parameters.
4
4
  1. Clean up repository files. See Cleaning Up Your Repository Files.
4
  1. Perform application-specific postupgrade tasks. See Additional Postupgrade Tasks for Specific Applications.
4
4
  1. Upgrade your encryption method to RC2 after your upgrade is complete and before you deploy your application. See Upgrading to RC2 Encryption.
4
4
  1. Set up your environment for support global time zone. See Setting Up Your Environment to Support Global Time Zone.
4
4
  1. Review planning considerations for migration from a non-Unicode code page to Unicode. See Migrating to Unicode.
4
4
  1. Upgrade regional servers. See Upgrading Regional Servers.
4
  1. Upgrade mobile and connected clients. See Upgrading Mobile and Connected Clients.
4
 Published: 20 October 2003
