Upgrade Guide for UNIX > Postupgrade Tasks > Postupgrade Tasks for All Environments >
Migrating Custom Business Components and Resolving Conflicts
This procedure only applies to development environment upgrades from Release 6.x to Release 7.5.
CAUTION:  Skip this procedure if you are upgrading a production environment or if you are upgrading from Release 7.x to Release 7.5.
After the Upgrade Siebel Database Schema phase, thoroughly review the post upgrade configuration to make sure that the object level definitions are preserved as expected.
The access control buscomp migration utility, upgcust.exe, is run on the Prior Customer Repository by the Upgrade Wizard during upgrade of the Siebel database schema. This utility reconfigures custom business component configurations on obsolete tables. However, you may need to perform manual steps to business component fields and joins, depending upon the complexity of your business component configuration, because in some cases, not all custom business component configurations are reconfigured by the access control buscomp migration utility. For example, complex customized business component configurations and customer business components which are based on customer extension columns or on Siebel columns in obsolete tables need to be identified and manually fixed after the upgrade.
During the upgrade, the access control buscomp migration utility, upgcust.exe, generates a log file titled upgcust.log that contains a list of business component joins and fields that need to be manually rectified. This particular log file, along with others generated by the upgrade process, can be found under SIEBEL_ROOT/log.
The log file contains two distinct sections:
 Published: 20 October 2003
