Upgrade Guide for UNIX > Postupgrade Tasks > Postupgrade Tasks for All Environments >
Updating the File System Directory
In your previous installation, the file system had a flat structure with one directory. The Release 7.x file system contains subdirectories. During the upgrade of your production environment, Siebel Anywhere looks for certain files in the file system subdirectories, but these files only exist in the root file system directory.
Therefore, you need to create the appropriate subdirectories in your previous installation directory structure and then copy the required files from the root file system directory to the new subdirectories.
To make file attachments accessible to Siebel Anywhere
  1. In the existing file system structure, create an /att subdirectory if it does not already exist; for example, /siebfile/att
    where:
    siebfile is your root file system directory.
  2. Copy all files located under the /siebfile directory to the //siebfile/att directory so that all file attachments will be accessible by Siebel eBusiness Applications.
  3. Verify that files have copied correctly to the //siebfile/att directory. After this has been verified, clean up the file system.
 Published: 20 October 2003
