Bookshelf Home | Contents | Index | Search | PDF |
Siebel Wireless Administration Guide For Financial Services > Configuring Siebel Wireless > Configuring Template Files and XSL >
Template File Overview
Because Siebel Wireless supports the smaller screen of a mobile phone or device, it uses a different set of templates than do other Siebel eBusiness Applications.
Similar to Siebel Wireless applet names and view names defined in Siebel Tools, all Siebel Wireless templates have names that start with SWLS. As with other Siebel Web Template files, these wireless template files each end with the .swt suffix.
NOTE: Any wireless templates that an administrator may create in addition to the templates that exist in Siebel Tools do not have to have a name that starts with SWLS, but following this convention will help you distinguish the wireless templates from others used for Siebel Web Client applications.
The wireless templates are located in the same directory as all other Siebel Web-based templates (
siebsrvr/WEBTMPL
). They can be edited in any standard text editor. They include the templates shown in Table 10.
Siebel Wireless Administration Guide For Financial Services Published: 18 April 2003 |
