Siebel Wireless Administration Guide For Financial Services > Configuring Siebel Wireless > Configuring Template Files and XSL >
XSL Stylesheet File Overview
In addition to the wireless templates, the siebsrvr/WEBTMPL directory also contains a series of XSL stylesheets used to render Siebel Wireless requests in HTML through the Siebel XML Web Interface. These XSL stylesheets are applied to wireless requests which have been identified to be XML requests, through the process described in Installing Siebel Wireless.
The XSL stylesheets also have names that begin with SWLS, and each stylesheet ends with the suffix .xsl. Like the wireless template files, these XSL stylesheets can be edited using any standard text editor. Table 11 shows the XSL stylesheet files.
Table 11.  XSL Stylesheets Descriptions
Template Filename
Description
SWLSLogin.xsl
Login page
SWLSMain.xsl
Main Menu page
SWLSListApplet.xsl
Display page
SWLSDetailApplet.xsl
Detail page
SWLSEdit.xsl
Edit, search, update, and data submit page
SWLSError.xsl
Error display page
SWLSPickApplet.xsl
Pick applet page
SWLSAssociationApplet.xsl
Association applet page
Particular XSL stylesheets are referenced in wireless template files using the swe:xsl-stylesheet tag. For example:
<swe:xsl-stylesheet name=SWLSLogin.xsl mode=process/>
Including this tag in a wireless template file results in the SWLSLogin.xsl stylesheet being applied to all Siebel Wireless applets and views that are associated with that template, assuming that the XML Web Interface is used to handle the request. Conditional tags can be used to apply variant XSL stylesheets (for example, for other markup languages such as cHTML), if these additional XSL stylesheets are maintained within the Siebel software.
 Published: 18 April 2003
